doc:lps:index [2017-05-05 15:25] bjorn |
doc:lps:index [2019-03-22 12:39] kristoffer |
- | <WRAP center round info> | + | ====== Loco positioning system ====== |
- | **IMPORTANT** | + | |
- | We're currently working on updating the documentation for the Loco positioning system. | + | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system. |
- | </WRAP> | + | * [[projects:lps:index|Hardware documentation]] |
+ | * [[https:// | ||
- | The Loco Positioning system (LPS) project is a set of hardware | + | To make the documentation easier to grasp there' |
+ | * **Deck | ||
+ | * **Tag and anchor:** These refer to roles when ranging (i.g depending | ||
- | ===== System overview ===== | + | ====== System overview |
- | * ToA ([[doc: | + | |
- | * [[doc: | + | |
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
- | This getting started documentation is intended to guide you from receiving your Loco Positioning Indoor Explorer Bundle to having an autonomous Crazyflie 2.0. | + | ===== Principles ===== |
+ | * [[doc: | ||
- | ==== Tools ==== | + | ===== Protocols ===== |
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== Implementations ===== | ||
+ | * [[doc: | ||
+ | ===== Tools ===== | ||
- | * [[doc: | + | * [[doc: |
* [[doc: | * [[doc: | ||
- | + | * [[https:// | |
- | ==== Prerequisites ==== | + | |
- | In order to illustrate | + | |
- | make clean | + | |
- | make | + | |
- | make cload | + | |
- | Use the [[doc: | + | |
- | Use the LPS tab of the Crazyflie client to store the physical anchor positions in the anchors. The communication from the client to the anchors is bridged through a Crazyflie, so you must have a Crazyflie with an Loco Positioning deck connected to the client. | + | |
- | The [[doc: | + | |
