doc:lps:index [2017-05-17 16:15] macke |
doc:lps:index [2018-11-05 16:10] kristoffer |
- | <WRAP center round info> | ||
- | **IMPORTANT** | ||
- | We're currently working on updating the documentation for the Loco positioning system. Until the documentation is completed you can find the early access documentation [[doc: | ||
Line 10: | Line 4: | ||
- | * [[https:// | + | * [[https:// |
Line 27: | Line 21: | ||
===== System set-up ===== | ===== System set-up ===== | ||
- | * [[doc: | + | * [[doc: |
* [[doc: | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== Principles ===== | ||
+ | * [[doc: | ||
===== Protocols ===== | ===== Protocols ===== | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
===== Tools ===== | ===== Tools ===== | ||
Line 39: | Line 44: | ||
- | + | * [[https:// | |
- | ====== Experimental functionality ====== | + | |
- | * [[doc: | + | |
