User Tools
Site Tools
doc:lps:index
Differences
Link to this comparison view
Next revision
Previous revision
doc:lps:index [2017-05-17 16:15]
macke
doc:lps:index [2020-05-12 14:56] (current)
Line 1: Line 1:
-<WRAP center round info+<WRAP center round important 60%
-**IMPORTANT** +This page has deprecated and moved to the new documentation framework of the main Bitcraze websitePlease go to [[https://www.bitcraze.io/documentation/system/]] or
- +[[https://www.bitcraze.io/documentation/repository/]]
-We're currently working on updating the documentation for the Loco positioning systemUntil the documentation is completed you can find the early access documentation [[doc:lps:earlyaccess|here]].+
 </WRAP> </WRAP>
Line 10: Line 9:
   * [[projects:lps:index|Hardware documentation]]   * [[projects:lps:index|Hardware documentation]]
   * [[https://www.bitcraze.io/getting-started-with-the-loco-positioning-system|Getting Started Guide]]   * [[https://www.bitcraze.io/getting-started-with-the-loco-positioning-system|Getting Started Guide]]
-  * [[https://github.com/bitcraze/lps-node-firmware|Loco Positioning Node firmware]] (with build instructions)+  * [[https://github.com/bitcraze/lps-node-firmware|Loco Positioning Node firmware]]
   * [[https://github.com/bitcraze/crazyflie-firmware|Crazyflie 2.0 firmware]]   * [[https://github.com/bitcraze/crazyflie-firmware|Crazyflie 2.0 firmware]]
Line 27: Line 26:
 ===== System set-up ===== ===== System set-up =====
-  * [[doc:lps:twr-reference-setup|Reference set-up]]: Our current TWR reference set-up showing node positioning and measurements+  * [[doc:lps:twr-reference-setup|Reference set-up]]: Our current reference set-up showing node positioning and measurements
   * [[doc:lps:anchor-setup|Anchor set-up]]: How to set-up, configure and mount the anchor   * [[doc:lps:anchor-setup|Anchor set-up]]: How to set-up, configure and mount the anchor
 +  * [[doc:crazyflie:client:pycfclient:index#firmware_configuration|Configure]] the Crazyflie 2.0 in 2Mbit radio mode. This reduces interference with the UWB radio. If the configuration is changed a restart of the Crazyflie 2.0 is required.
 +  * [[doc:lps:starting-position|Crazyflie starting position]]: How to place the Crazyflie when using the LPS
 +  * [[doc:lps:configure-mode|Configure LPS system mode wirelessly]]
 +  * [[doc:lps:toda3|TDoA 3 set up]]
 +  * [[doc:lps:anchor-low-level-config|Anchor low level configuration]]
 +===== Principles =====
 +  * [[doc:lps:tdoa:principles|TDoA positioning principles]]: A description of how positioning using TDoA works
 +  * [[doc:lps:tdoa:tdoa2-vs-tdoa3|TDoA2 VS TDoA3]]: A description the differences between TDoA2 and TDoA3
 ===== Protocols ===== ===== Protocols =====
   * [[doc:lps:lpp#two_way_ranging|TWR protocol]]: Documents the protocol used for Two Way Ranging (TWR)   * [[doc:lps:lpp#two_way_ranging|TWR protocol]]: Documents the protocol used for Two Way Ranging (TWR)
 +  * [[doc:lps:tdoa:protocol|TDoA 2 protocol]]: Documentation of the TDoA 2 anchor protocol
 +  * [[doc:lps:tdoa3:protocol|TDoA 3 protocol]]: Documentation of the TDoA 3 anchor protocol
 +===== Implementations =====
 +  * [[doc:lps:tdoa3:implementation|TDoA 3 implementation]]: Documentation of the TDoA 3 implementation
 ===== Tools ===== ===== Tools =====
Line 39: Line 54:
   * [[doc:lps:tools#lps_configuration_tool|LPS configuration tool]] - Used for firmware upgrades, changing mode and setting the address of Loco positioning nodes   * [[doc:lps:tools#lps_configuration_tool|LPS configuration tool]] - Used for firmware upgrades, changing mode and setting the address of Loco positioning nodes
   * [[doc:lps:ros|ROS]] - Used for controlling Crazyflies   * [[doc:lps:ros|ROS]] - Used for controlling Crazyflies
- +  * [[https://github.com/bitcraze/crazyflie-lib-python/blob/master/examples/autonomousSequence.py|Autonomous sequence sctripting]] - Example showing how to use the [[https://github.com/bitcraze/crazyflie-lib-python|Crazyflie Python Library]] to create scripted autonomous flights
-It is also possible to script movements using the [[https://github.com/bitcraze/crazyflie-lib-python|Crazyflie Python Library]] ([[https://github.com/bitcraze/crazyflie-lib-python/blob/master/examples/autonomousSequence.py|example]]+
-====== Experimental functionality ====== +
-  * [[doc:lps:tdoa|TDoA]]: How to build custom Crazyflie 2.0 firmware and enable TDoA mode in the anchors+
doc/lps/index.1495030514.txt.gz · Last modified: 2017-05-17 16:15 by macke
