Next revision | Previous revision Last revision Both sides next revision | ||
doc:lps:lpp [2017-02-18 11:28] arnaud created |
doc:lps:lpp [2019-09-05 14:37] kimberly |
+ | This page is deprecated and is moved to the main Bitcraze website. Please go to [[https:// | ||
====== Loco Positioning Protocol ====== | ====== Loco Positioning Protocol ====== | ||
Line 4: | Line 9: | ||
The ranging messages are sent and received directly by the ranging algorithms in the Crazyflie and in the Nodes. The management message are sent by management tools like the Crazyflie client. | The ranging messages are sent and received directly by the ranging algorithms in the Crazyflie and in the Nodes. The management message are sent by management tools like the Crazyflie client. | ||
+ | ===== Ranging protocols ===== | ||
+ | All ranging packet share the same format: | ||
+ | ^ byte ^ value ^ note ^ | ||
+ | | 0 | ID | Packet ID | | ||
+ | | 1.. | Payload | Format is defined per ID | | ||
+ | ==== Two Way Ranging ==== | ||
+ | The two way ranging protocol allows a tag to measure its distance to an anchor. The protocol contains 4 messages, two are sent by the tag two by the anchor. The message sequence is as follow: | ||
+ | The time of flight is calculated using the formula: | ||
+ | TWR packet IDs | ||
+ | ^ ID ^ Description ^ | ||
+ | | 0x01 | [[doc: | ||
+ | | 0x02 | [[doc: | ||
+ | | 0x03 | [[doc: | ||
+ | | 0x04 | [[doc: | ||
+ | === TWR_POLL === | ||
+ | Format: | ||
+ | ^ Payload byte ^ Name ^ Note ^ | ||
+ | === TWR_ANSWER === | ||
+ | Format: | ||
+ | The optional management data can be any LPP management packet deemed useful for the tag. Currently this is used to send the anchor position from the anchor to the tag using the [[doc: | ||
+ | === TWR_FINAL === | ||
+ | Format: | ||
+ | === TWR_REPORT === | ||
+ | Format: | ||
+ | | 1.. | Report | Report structure, see format bellow | | ||
+ | Report structure format: | ||
+ | <code c> | ||
+ | typedef struct { | ||
+ | uint8_t pollRx[5]; | ||
+ | uint8_t answerTx[5]; | ||
+ | uint8_t finalRx[5]; | ||
+ | float pressure; | ||
+ | float temperature; | ||
+ | float asl; // Above Sea Level altitude | ||
+ | uint8_t pressure_ok; | ||
+ | } __attribute__((packed)) lpsTwrTagReportPayload_t; | ||
===== Management protocols ===== | ===== Management protocols ===== | ||
Line 14: | Line 86: | ||
^ byte ^ value ^ note ^ | ^ byte ^ value ^ note ^ | ||
| 0 | 0xF0 | LPP short | | | 0 | 0xF0 | LPP short | | ||
- | | 1 | + | | 1 |
| 2..17 | Payload | Format is defined per ID | | | 2..17 | Payload | Format is defined per ID | | ||
LPP Short packet IDs: | LPP Short packet IDs: | ||
- | ^ ID ^ Description ^ | + | ^ LPPS_ID |
| 0x01 | [[doc: | | 0x01 | [[doc: | ||
