doc:lps:tdoa:protocol [2017-08-31 17:09] arnaud |
doc:lps:tdoa:protocol [2019-09-05 14:43] kimberly |
====== TDoA Anchor protocol V2 ====== | ====== TDoA Anchor protocol V2 ====== | ||
Line 22: | Line 31: | ||
typedef struct rangePacket_s { | typedef struct rangePacket_s { | ||
uint8_t type; | uint8_t type; | ||
- | uint8_t seqs[NSLOTS]; // Packet sequence number of the timestamps | + | uint8_t seqs[8]; // Packet sequence number of the timestamps |
- | uint16_t distances[NSLOTS]; | + | uint16_t distances[8]; |
} __attribute__((packed)) rangePacket_t; | } __attribute__((packed)) rangePacket_t; | ||
Line 48: | Line 57: | ||
===== Calculating TDoA ===== | ===== Calculating TDoA ===== | ||
+ | [[doc: | ||
