doc:lps:tdoa:protocol [2017-09-11 09:15] arnaud |
doc:lps:tdoa:protocol [2018-11-05 17:37] kristoffer |
Line 22: | Line 22: | ||
typedef struct rangePacket_s { | typedef struct rangePacket_s { | ||
uint8_t type; | uint8_t type; | ||
- | uint8_t seqs[NSLOTS]; // Packet sequence number of the timestamps | + | uint8_t seqs[8]; // Packet sequence number of the timestamps |
- | uint16_t distances[NSLOTS]; | + | uint16_t distances[8]; |
} __attribute__((packed)) rangePacket_t; | } __attribute__((packed)) rangePacket_t; | ||
Line 48: | Line 48: | ||
===== Calculating TDoA ===== | ===== Calculating TDoA ===== | ||
- | For an example of how to calculate TDoA of packets using this protocol you can look at the Crazyflie source code: https:// | + | [[doc: |
- | If we consider the 3 last packets sent from anchor 0 and 1: | + | |
- | {{:doc: | + | |
- | We can calculate the difference of time of flight (which is the difference of time of arrival, TDoA) by calculating the diffence between δtx and δrx. From the tag side this can be done by receiving the last packet from each anchors: | + | |
- | δrx is measured when receiving the two packets. δtx can be calculated if we know the time it takes to fly from 0 to 1: Anchor 1 measures the time of arrival of the packet P2 and so knowing the time it took the packet to arrive to 1, we can calculate when it was sent by 0. The time of flight between 0 and 1 is measured by the anchors and transmitted in the packets. It is measured using two way ranging: | + | |
- | Once we know the transmit time of P2 in the anchor 1, we can calculate δtx and δrx. Though δtx is expressed in the Anchor 1 clock. Each node has an imperfect clock and we need to compensate for drift between the clocks. To do so the tag uses two consecutive packet from Anchor 1 to keep track of the clock drift coefficient between its own clock and Anchor 1 clock: | + | |
- | Using these two packet we can calculate α₁ = δrx1 / δtx1. We can now calculate | + | |
