doc:lps:tdoa [2017-11-15 17:08] kristoffer |
doc:lps:tdoa [2017-12-11 15:23] arnaud |
Line 8: | Line 8: | ||
- Configure the LPS nodes in TDoA by opening the serial console and pressing " | - Configure the LPS nodes in TDoA by opening the serial console and pressing " | ||
- Set the address of the LPS nodes **from 0 to 7**. TDoA works with up to 8 anchors and they much now be addressed from 0 | - Set the address of the LPS nodes **from 0 to 7**. TDoA works with up to 8 anchors and they much now be addressed from 0 | ||
- | - Compile and flash the Crazyflie firmware with " | + | - Compile and flash the Crazyflie firmware with " |
The anchor placement is even more important with TDoA than with TWR. The Crazyflie must fly within the 3D [[https:// | The anchor placement is even more important with TDoA than with TWR. The Crazyflie must fly within the 3D [[https:// |
