doc:lps:toda3 [2018-06-15 08:08] kristoffer |
doc:lps:toda3 [2020-05-12 14:08] (current) kimberly |
| - | ====== TDoA 3 set up ====== | + | <WRAP center round important 60%> |
| - | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// | |
| - | <WRAP center round tip 80%> | + | |
| - | **NOTE** | + | |
| - | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
| - | ===== Compile and flash ===== | ||
| - | To try it out you will have to do the following: | + | ====== TDoA 3 set up ====== |
| - | ==== The Crazyflie | + | TDoA 3 is part of the official |
| - | * Get the latest source code for the firmware from [[https:// | + | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct |
| - | * Compile for TDoA3 and force the TDoA mode with '' | + | If you want to force the Crazyflie |
| - | * Flash the Crazyflie | + | |
| ==== The LPS Nodes ==== | ==== The LPS Nodes ==== | ||
| - | * Get the latests source code for the firmware from [[https:// | ||
| - | * Compile | ||
| - | * Flash the nodes using '' | ||
| * Configure the Nodes as anchors, and set the mode to TDoA 3 | * Configure the Nodes as anchors, and set the mode to TDoA 3 | ||
| - | * Anchor positions can be set using the python client | + | * Set anchor positions, see below. |
| + | ===== Setting anchor positions ===== | ||
| + | Anchor positions can be set by the python client | ||
| + | You might have to move the Crazyflie close to all anchors | ||
| + | All the anchors work in the same coordinate system, so you need to choose a common origin for your system. Try to expand your system step by step, testing it at each step to catch problem when they start to happen. | ||
| ===== 2D positioning ===== | ===== 2D positioning ===== | ||
| Line 29: | Line 28: | ||
| Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
| - | For instance '' | + | For instance '' |
| - | ===== Longer range ===== | + | ===== Longer range and lower bitrate |
| + | Note: this is experimental functionality that is not fully tested or might not work as expected. | ||
| In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | ||
| - | Recompile | + | Recompile |
| - | Example: '' | + | Example: '' |
| + | There is a setting for the bitrate in the Anchor configuration when connecting using USB. | ||
| ===== Longer preamble ===== | ===== Longer preamble ===== | ||
| It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | ||
| + | The preamble is used by the anchor radios to detect messages and a longer preamble increase the probability and thus the useful distance. | ||
| + | Note that the radios might detect the preamble but fail at reading the data of the packet (see lower bitrate above). The " | ||
| ==== The Crazyflie ==== | ==== The Crazyflie ==== | ||
| Line 52: | Line 59: | ||
| - | * Find the src/uwb.c file | + | * There is a configuration setting for the preamble length |
| - | * Locate the call to dwEnableMode() | + | |
| - | * Change the second argument to MODE_LONGDATA_MID_ACCURACY | + | |
| - | * Find the src/ | + | |
| - | * Locate the line where PREAMBLE_LENGTH_S is defined | + | |
| - | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | + | |
| - | * Compile and flash | + | |
| ===== Sniffing ===== | ===== Sniffing ===== | ||
| - | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | + | Sniffing the system is useful when you want to start digging into the radio messages exchanged between the anchor. It is a debug functionality. |
| + | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. | ||
| ==== Basic sniffing ==== | ==== Basic sniffing ==== | ||
| Line 80: | Line 83: | ||
| example: '' | example: '' | ||
| - | ==== Time of flight ==== | + | ==== Time of flight |
| By piping the TDoA 3 data into the TOF tool, the measured anchor to anchor distances will be displayed. By adding the ' | By piping the TDoA 3 data into the TOF tool, the measured anchor to anchor distances will be displayed. By adding the ' | ||
