doc:lps:toda3 [2018-06-13 13:54] kristoffer |
doc:lps:toda3 [2018-06-15 08:08] kristoffer |
Line 5: | Line 5: | ||
The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | ||
+ | ===== Compile and flash ===== | ||
To try it out you will have to do the following: | To try it out you will have to do the following: | ||
- | ===== The Crazyflie | + | ==== The Crazyflie ==== |
* Get the latest source code for the firmware from [[https:// | * Get the latest source code for the firmware from [[https:// | ||
Line 14: | Line 16: | ||
* Flash the Crazyflie with '' | * Flash the Crazyflie with '' | ||
- | ===== The LPS Nodes ===== | + | ==== The LPS Nodes ==== |
* Get the latests source code for the firmware from [[https:// | * Get the latests source code for the firmware from [[https:// | ||
Line 31: | Line 33: | ||
===== Longer range ===== | ===== Longer range ===== | ||
- | In this mode the UWB bitrate is lower and the messages | + | In this mode the UWB bitrate is lower and the data of messages |
Recompile both Crazyflie and anchors with the LPS_LONGER_RANGE compile flag. | Recompile both Crazyflie and anchors with the LPS_LONGER_RANGE compile flag. | ||
Line 37: | Line 39: | ||
Example: '' | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * Find the src/uwb.c file | ||
+ | * Locate the line where PREAMBLE_LENGTH_S is defined | ||
+ | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | ||
+ | example: '' | ||
+ | ==== Time of flight ==== | ||
+ | example: '' |
