doc:lps:toda3 [2018-06-15 08:08] kristoffer |
doc:lps:toda3 [2018-08-22 14:44] kristoffer |
Line 13: | Line 13: | ||
* Get the latest source code for the firmware from [[https:// | * Get the latest source code for the firmware from [[https:// | ||
* Flash the Crazyflie with '' | * Flash the Crazyflie with '' | ||
+ | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | ||
+ | If you want to force the Crazyflie to use TDoA3 on startup, use the LPS_TDOA3_ENABLE=1 compile option | ||
==== The LPS Nodes ==== | ==== The LPS Nodes ==== | ||
Line 22: | Line 24: | ||
* Flash the nodes using '' | * Flash the nodes using '' | ||
- | * Anchor positions can be set using the python client | + | * Set anchor positions, see below. |
+ | ===== Setting anchor positions ===== | ||
+ | Anchor positions can be set by the python client | ||
+ | The tool uses a Crazyflie as a bridge to transmit UWB messages to the anchors. When it is started it transmits positions for all anchors over and over, | ||
+ | * Create a file with your anchor positions, see tools/ | ||
+ | * Start the Crazyflie | ||
+ | * Pipe the position file into the tool using the URI of your copter '' | ||
+ | * Move the Crazyflie close to all anchors to transfer the positions | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | ||
+ | example: '' | ||
===== 2D positioning ===== | ===== 2D positioning ===== | ||
Line 31: | Line 71: | ||
For instance '' | For instance '' | ||
- | ===== Longer range ===== | + | ===== Longer range and lower bitrate |
In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | ||
Line 42: | Line 82: | ||
It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | ||
==== The Crazyflie ==== | ==== The Crazyflie ==== | ||
Line 60: | Line 102: | ||
* Compile and flash | * Compile and flash | ||
- | ===== Sniffing ===== | ||
- | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | ||
- | ==== Basic sniffing ==== | ||
- | Connect the sniffer via USB and check in /dev which port that it uses. Use this as the first argument | ||
- | The second argument is the output format, use yaml | ||
- | example: '' | ||
- | ==== TDoA 3 parsing ==== | ||
- | Pipe the yaml into the TDoA 3 decoder to see TDoA 3 data unpacked | ||
- | This will show all data that the sniffer receives. To limit the output it is possible to filter which anchors to show. Add one or more ids at the end to only show data from only these anchors. | ||
- | ==== Time of flight ==== | ||
- | By piping the TDoA 3 data into the TOF tool, the measured anchor to anchor distances will be displayed. By adding the ' | ||
- | example: '' |
