doc:lps:toda3 [2018-06-15 08:08] kristoffer |
doc:lps:toda3 [2018-11-06 14:10] arnaud |
- | <WRAP center round tip 80%> | + | TDoA 3 is part of the official Crazyflie and LPS Node firmware releases since 2018.10. |
- | **NOTE** | + | |
- | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
- | ===== Compile | + | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. |
+ | If you want to force the Crazyflie to use TDoA3 on startup, use the LPS_TDOA3_ENABLE=1 compile option | ||
- | To try it out you will have to do the following: | + | ==== The LPS Nodes ==== |
- | ==== The Crazyflie ==== | + | * Configure the Nodes as anchors, and set the mode to TDoA 3 |
+ | * Set anchor positions, see below. | ||
- | * Get the latest source code for the firmware from [[https:// | + | ===== Setting anchor positions ===== |
- | * Compile for TDoA3 and force the TDoA mode with '' | + | |
- | * Flash the Crazyflie with '' | + | |
- | ==== The LPS Nodes ==== | + | Anchor positions can be set by the python client or the tool in the lps-node-firmware repo. |
+ | You might have to move the Crazyflie close to all anchors to transfer the positions from the Crazyflie. | ||
- | * Get the latests source code for the firmware from [[https:// | + | All the anchors work in the same coordinate system, so you need to choose a common origin |
- | * Compile | + | |
- | * Flash the nodes using '' | + | |
- | * Configure the Nodes as anchors, and set the mode to TDoA 3 | + | |
- | * Anchor positions can be set using the python client (0 - 7) but if you have more anchors you will have toools/ | + | |
===== 2D positioning ===== | ===== 2D positioning ===== | ||
Line 29: | Line 23: | ||
Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
- | For instance '' | + | For instance '' |
- | ===== Longer range ===== | + | ===== Longer range and lower bitrate |
In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | ||
- | Recompile | + | Recompile |
- | Example: '' | + | Example: '' |
===== Longer preamble ===== | ===== Longer preamble ===== | ||
It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | ||
==== The Crazyflie ==== | ==== The Crazyflie ==== | ||
Line 52: | Line 54: | ||
==== The LPS Nodes ==== | ==== The LPS Nodes ==== | ||
- | * Find the src/uwb.c file | + | * There is a configuration setting for the preamble length |
- | * Locate the call to dwEnableMode() | + | |
- | * Change the second argument to MODE_LONGDATA_MID_ACCURACY | + | |
- | * Find the src/ | + | |
- | * Locate the line where PREAMBLE_LENGTH_S is defined | + | |
- | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | + | |
- | * Compile and flash | + | |
===== Sniffing ===== | ===== Sniffing ===== | ||
- | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | + | Sniffing the system is useful when you want to start digging into the radio messages exchanged between the anchor. It is a debug functionality. |
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. | ||
==== Basic sniffing ==== | ==== Basic sniffing ==== | ||
Line 80: | Line 78: | ||
example: '' | example: '' | ||
- | ==== Time of flight ==== | + | ==== Time of flight |
By piping the TDoA 3 data into the TOF tool, the measured anchor to anchor distances will be displayed. By adding the ' | By piping the TDoA 3 data into the TOF tool, the measured anchor to anchor distances will be displayed. By adding the ' | ||
