doc:lps:toda3 [2018-08-22 14:44] kristoffer |
doc:lps:toda3 [2018-10-31 18:21] kristoffer |
- | <WRAP center round tip 80%> | + | TDoA 3 is part of the official |
- | **NOTE** | + | |
- | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
- | ===== Compile and flash ===== | + | |
- | To try it out you will have to do the following: | + | |
- | ==== The Crazyflie | + | |
- | * Get the latest source code for the firmware | + | |
- | * Flash the Crazyflie with '' | + | |
The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | ||
Line 20: | Line 8: | ||
==== The LPS Nodes ==== | ==== The LPS Nodes ==== | ||
- | * Compile | ||
* Set anchor positions, see below. | * Set anchor positions, see below. | ||
Line 28: | Line 13: | ||
===== Setting anchor positions ===== | ===== Setting anchor positions ===== | ||
- | Anchor positions can be set by the python client | + | Anchor positions can be set by the python client |
- | + | You might have to move the Crazyflie close to all anchors to transfer the positions | |
- | The tool uses a Crazyflie as a bridge | + | |
- | * Create a file with your anchor positions, see tools/ | + | |
- | * Start the Crazyflie | + | |
- | * Pipe the position file into the tool using the URI of your copter '' | + | |
- | * Move the Crazyflie close to all anchors to transfer the positions | + | |
===== Sniffing ===== | ===== Sniffing ===== | ||
- | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | + | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. |
==== Basic sniffing ==== | ==== Basic sniffing ==== | ||
Line 69: | Line 48: | ||
Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
- | For instance '' | + | For instance '' |
===== Longer range and lower bitrate ===== | ===== Longer range and lower bitrate ===== | ||
In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | ||
- | Recompile | + | Recompile |
- | Example: '' | + | Example: '' |
===== Longer preamble ===== | ===== Longer preamble ===== | ||
It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | ||
Line 94: | Line 79: | ||
- | * Find the src/uwb.c file | + | * There is a configuration setting for the preamble length |
- | * Locate the call to dwEnableMode() | + | |
- | * Change the second argument to MODE_LONGDATA_MID_ACCURACY | + | |
- | * Find the src/ | + | |
- | * Locate the line where PREAMBLE_LENGTH_S is defined | + | |
- | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | + | |
- | * Compile and flash | + | |
