doc:lps:toda3 [2018-08-22 14:44] kristoffer |
doc:lps:toda3 [2020-05-12 14:08] (current) kimberly |
- | ====== TDoA 3 set up ====== | + | <WRAP center round important 60%> |
- | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// | |
- | <WRAP center round tip 80%> | + | |
- | **NOTE** | + | |
- | The TDoA3 mode is experimental. The protocol and implementation might change but is fairly stable. | + | |
- | ===== Compile and flash ===== | ||
- | To try it out you will have to do the following: | + | ====== TDoA 3 set up ====== |
- | ==== The Crazyflie | + | |
- | * Get the latest source code for the firmware | + | TDoA 3 is part of the official Crazyflie and LPS Node firmware |
- | * Flash the Crazyflie with '' | + | |
The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | The Crazyflie will automatically detect that the positioning system is using TDoA3 and switch to the correct mode. | ||
Line 20: | Line 13: | ||
==== The LPS Nodes ==== | ==== The LPS Nodes ==== | ||
- | * Compile | ||
* Set anchor positions, see below. | * Set anchor positions, see below. | ||
Line 28: | Line 18: | ||
===== Setting anchor positions ===== | ===== Setting anchor positions ===== | ||
- | Anchor positions can be set by the python client | + | Anchor positions can be set by the python client |
- | + | You might have to move the Crazyflie close to all anchors to transfer the positions from the Crazyflie. | |
- | The tool uses a Crazyflie as a bridge | + | |
- | * Create a file with your anchor positions, see tools/ | + | |
- | * Start the Crazyflie | + | |
- | * Pipe the position file into the tool using the URI of your copter '' | + | |
- | * Move the Crazyflie close to all anchors to transfer the positions | + | |
- | ===== Sniffing ===== | + | |
- | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | + | |
- | ==== Basic sniffing ==== | + | |
- | Connect the sniffer via USB and check in /dev which port that it uses. Use this as the first argument | + | |
- | The second argument is the output format, use yaml | + | |
- | example: '' | + | |
- | ==== TDoA 3 parsing ==== | + | |
- | Pipe the yaml into the TDoA 3 decoder to see TDoA 3 data unpacked | + | |
- | This will show all data that the sniffer receives. To limit the output it is possible to filter which anchors to show. Add one or more ids at the end to only show data from only these anchors. | + | |
- | ==== Time of flight and anchor to anchor distance ==== | + | |
- | By piping | + | |
+ | All the anchors work in the same coordinate system, so you need to choose a common origin for your system. Try to expand your system step by step, testing it at each step to catch problem when they start to happen. | ||
===== 2D positioning ===== | ===== 2D positioning ===== | ||
Line 69: | Line 28: | ||
Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
- | For instance '' | + | For instance '' |
===== Longer range and lower bitrate ===== | ===== Longer range and lower bitrate ===== | ||
In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | In this mode the UWB bitrate is lower and the data of messages can be read at a longer distance. The packet rate will be reduced though. | ||
- | Recompile | + | Recompile |
- | Example: '' | + | Example: '' |
===== Longer preamble ===== | ===== Longer preamble ===== | ||
It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | It is possible to use a longer preamble, this will also reduce packet rate. There is no compile flag for this setting, it requires some code modifications in the Crazyflie and the anchors. | ||
Line 94: | Line 59: | ||
- | * Find the src/uwb.c file | + | * There is a configuration setting for the preamble length |
- | * Locate | + | |
- | * Change | + | ===== Sniffing ===== |
- | * Find the src/uwb_tdoa_anchor3.c file | + | |
- | * Locate | + | Sniffing the system is useful when you want to start digging into the radio messages exchanged between the anchor. It is a debug functionality. |
- | * Change | + | |
- | * Compile | + | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor |
+ | Connect | ||
+ | example: '' | ||
+ | This will show all data that the sniffer receives. To limit the output | ||
+ | ==== Time of flight | ||
