doc:lps:twr-tdma [2017-07-18 15:41] arnaud [Compiling Crazyflie for TWR-TDMA ranging] |
doc:lps:twr-tdma [2021-06-24 16:54] (current) kimberly |
| ====== TWR-TDMA ====== | ====== TWR-TDMA ====== | ||
| + | <WRAP center round important> | ||
| + | **Note**: TWR-TDMA is now considered obsolete and replaced by the TDoA modes. TDoA will generally have better performance than TWR-TDMA, TWR might still be useful to you though but if you are setting up a single room system TDoA is most likely the way to go. | ||
| ===== Abstract ===== | ===== Abstract ===== | ||
| Line 16: | Line 24: | ||
| In order to activate TWR-TDMA, you need to recompile the Crazyflie firmware. Add the following to ' | In order to activate TWR-TDMA, you need to recompile the Crazyflie firmware. Add the following to ' | ||
| LPS_TDMA_ENABLE=1 | LPS_TDMA_ENABLE=1 | ||
| CFLAGS += -DTDMA_NSLOTS_BITS=1 | CFLAGS += -DTDMA_NSLOTS_BITS=1 | ||
| Line 24: | Line 32: | ||
| * **LPS_TDMA_ENABLE=1** Enable the TDMA mode for TWR | * **LPS_TDMA_ENABLE=1** Enable the TDMA mode for TWR | ||
| * **TDMA_NSLOTS_BITS=1** Configures 2 time slot (good for 2 tags) per frame. The number of time slot per frame is 2^TDMA_NSLOTS_BITS | * **TDMA_NSLOTS_BITS=1** Configures 2 time slot (good for 2 tags) per frame. The number of time slot per frame is 2^TDMA_NSLOTS_BITS | ||
| - | * **TDMA_SLOT** Optionally hardcode the time slot. See bellow for time slot auto-configuration. | + | * **TDMA_SLOT** Optionally hardcode the time slot. See bellow for time slot auto-configuration |
| ===== Configuring time slots ===== | ===== Configuring time slots ===== | ||
