misc:investigations:lps-precision [2017-05-11 14:44] kristoffer |
misc:investigations:lps-precision [2017-07-07 09:29] arnaud [The results] |
Line 23: | Line 23: | ||
| 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | | 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | ||
+ | [[https:// | ||
===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ||
Line 48: | Line 49: | ||
=== Analysis === | === Analysis === | ||
- | Physical distances from Crazyflie to anchors are calculated from positions of anchors and the Crazyflie. | + | == Estimated position == |
+ | ^ Physical position ^^^ Average estimated position ^^^^^^ Std-dev of estimated position ^^^ Average error ^ | ||
+ | ^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ distance ^ | ||
+ | | 5.00 | 1.50 | 0.76 | 4.96 | 0.017 | 1.60 | 0.041 | -0.096 | -0.213 | 0.017 | 0.018 | 0.015 | 0.237 | | ||
- | ^ ^ Physical ^ Raw measurements | + | == Raw range measurements |
- | ^ Anchor ^ Distance ^ Average ^ Std dev ^ | + | |
- | | 0 | 2.80 | | + | Physical distances from Crazyflie to anchors are calculated from positions of anchors and the Crazyflie. |
- | | 1 | 2.87 | | + | |
- | | 2 | 2.69 | | + | |
- | | 3 | 2.77 | | + | |
- | | 4 | 2.27 | | + | |
- | | 5 | 2.20 | | + | |
+ | Average and standard deviations are calculated on all data, including outliers. | ||
+ | The main part of the error should be caused by the antenna delay, expected to be the same for all anchors. | ||
+ | ^ ^ Physical ^ Raw range measurements ^^^ | ||
+ | ^ Anchor ^ Distance ^ Average ^ Std dev ^ Err ^ | ||
+ | | 0 | 2.80 | 2.46 | 0.025 | 0.34 | | ||
+ | | 1 | 2.87 | 2.58 | 0.006 | 0.30 | | ||
+ | | 2 | 2.69 | 2.30 | 0.002 | 0.40 | | ||
+ | | 3 | 2.77 | 2.55 | 0.017 | 0.22 | | ||
+ | | 4 | 2.27 | 1.97 | 0.041 | 0.29 | | ||
+ | | 5 | 2.20 | 1.90 | 0.008 | 0.30 | | ||
+ | == Histogram over raw range measurements == | ||
