| Anchor | X | Y | Z |
| 0 | 3.01 | 0.57 | 2.5 |
| 1 | 3.01 | 2.63 | 2.5 |
| 2 | 6.53 | 2.27 | 2.84 |
| 3 | 6.53 | 0.51 | 2.84 |
| 4 | 2.91 | 0.86 | 0.16 |
| 5 | 6.95 | 2.32 | 0.16 |
| Physical | Raw measurements | ||
| Anchor | Distance | Average | Std dev |
| 0 | 2.80 | ||
| 1 | 2.87 | ||
| 2 | 2.69 | ||
| 3 | 2.77 | ||
| 4 | 2.27 | ||
| 5 | 2.20 | ||
