User Tools
Site Tools
misc:investigations:lps-precision
Differences
Link to this comparison view
Next revision
Previous revision
misc:investigations:lps-precision [2017-05-11 15:05]
misc:investigations:lps-precision [2017-07-07 09:29]
arnaud [The results]
Line 23: Line 23:
 | 1.62 | 4.80 | 1.44  | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013  | 0.0093 | 0.013 | | 1.62 | 4.80 | 1.44  | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013  | 0.0093 | 0.013 |
 +[[https://docs.google.com/spreadsheets/d/1ggHmUmRQ1N15vgPnumlmCsrpjw32Cm7DYKf-GYCoKck|Raw data]]
 ===== Measurement of accuracy and noise of 3D estimate and ranges ===== ===== Measurement of accuracy and noise of 3D estimate and ranges =====
Line 47: Line 48:
 === Analysis === === Analysis ===
 +== Estimated position ==
 +^ Physical position ^^^ Average estimated position ^^^^^^ Std-dev of estimated position ^^^ Average error ^
 +^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ distance ^
 +| 5.00 | 1.50 | 0.76 | 4.96 | 0.017 | 1.60 | 0.041 | -0.096 | -0.213 | 0.017 | 0.018 | 0.015 | 0.237 |
 +== Raw range measurements ==
 Physical distances from Crazyflie to anchors are calculated from positions of anchors and the Crazyflie. Physical distances from Crazyflie to anchors are calculated from positions of anchors and the Crazyflie.
 +Average and standard deviations are calculated on all data, including outliers.
 +The main part of the error should be caused by the antenna delay, expected to be the same for all anchors.
 ^ ^ Physical ^ Raw range measurements ^^^ ^ ^ Physical ^ Raw range measurements ^^^
Line 60: Line 72:
 |  5  | 2.20 | 1.90 | 0.008 | 0.30 | |  5  | 2.20 | 1.90 | 0.008 | 0.30 |
 +== Histogram over raw range measurements ==
 +{{:misc:investigations:hist_ref_setup.png?direct|}}
misc/investigations/lps-precision.txt · Last modified: 2021-06-24 16:39 by kimberly
