misc:investigations:lps-precision
Measurements of accuracy and precision of the Loco Positioning system
Multiple measurements in reference system
The reference system
The results
Physical position Average estimated position Std-dev of estimated position
X Y Z X Err Y Err Z Err X Y Z
1.62 3.15 -0.15 1.66 0.04 3.18 0.03 0.29 0.44 0.014 0.0097 0.0061
2.95 0.00 -0.15 2.80 -0.15 0.12 0.12 0.16 0.31 0.0072 0.010 0.0053
1.62 3.15 1.44 1.56 0.06 3.02 -0.13 1.37 -0.07 0.020 0.0066 0.016
1.62 4.80 1.44 1.67 0.03 4.64 -0.16 1.40 -0.27 0.013 0.0093 0.013
Raw data
Measurement of accuracy and noise of 3D estimate and ranges
Setup
Positions
Anchor X Y Z
0 3.01 0.57 2.5
1 3.01 2.63 2.5
2 6.53 2.27 2.84
3 6.53 0.51 2.84
4 2.91 0.86 0.16
5 6.95 2.32 0.16
Measurements
Analysis
Estimated position
Physical position Average estimated position Std-dev of estimated position Average error
X Y Z X Err Y Err Z Err X Y Z distance
5.00 1.50 0.76 4.96 0.017 1.60 0.041 -0.096 -0.213 0.017 0.018 0.015 0.237
Raw range measurements
Average and standard deviations are calculated on all data, including outliers.
The main part of the error should be caused by the antenna delay, expected to be the same for all anchors.
Physical Raw range measurements
Anchor Distance Average Std dev Err
0 2.80 2.46 0.025 0.34
1 2.87 2.58 0.006 0.30
2 2.69 2.30 0.002 0.40
3 2.77 2.55 0.017 0.22
4 2.27 1.97 0.041 0.29
5 2.20 1.90 0.008 0.30
Histogram over raw range measurements
misc/investigations/lps-precision.1499412553.txt.gz · Last modified: 2017-07-07 09:29 by arnaud
