misc:investigations:lps-precision [2017-05-11 16:04] kristoffer |
misc:investigations:lps-precision [2021-06-24 16:39] kimberly |
====== Measurements of accuracy and precision of the Loco Positioning system ====== | ====== Measurements of accuracy and precision of the Loco Positioning system ====== | ||
Line 23: | Line 26: | ||
| 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | | 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | ||
+ | [[https:// | ||
===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ||
Line 60: | Line 64: | ||
Average and standard deviations are calculated on all data, including outliers. | Average and standard deviations are calculated on all data, including outliers. | ||
- | The main part of the error should be the caused by the antenna delay, expected to be the same for all anchors. | + | The main part of the error should be caused by the antenna delay, expected to be the same for all anchors. |
^ ^ Physical ^ Raw range measurements ^^^ | ^ ^ Physical ^ Raw range measurements ^^^ | ||
Line 71: | Line 75: | ||
| 5 | 2.20 | 1.90 | 0.008 | 0.30 | | | 5 | 2.20 | 1.90 | 0.008 | 0.30 | | ||
+ | == Histogram over raw range measurements == | ||
