| Anchor | X | Y | Z |
| 0 | 3.01 | 0.57 | 2.5 |
| 1 | 3.01 | 2.63 | 2.5 |
| 2 | 6.53 | 2.27 | 2.84 |
| 3 | 6.53 | 0.51 | 2.84 |
| 4 | 2.91 | 0.86 | 0.16 |
| 5 | 6.95 | 2.32 | 0.16 |
| Physical position | Average estimated position | Std-dev of estimated position | Average error | |||||||||
| X | Y | Z | X | Err | Y | Err | Z | Err | X | Y | Z | distance |
| 5.00 | 1.50 | 0.76 | 4.96 | 0.017 | 1.60 | 0.041 | -0.096 | -0.213 | 0.017 | 0.018 | 0.015 | 0.237 |
Average and standard deviations are calculated on all data, including outliers.
The main part of the error should be caused by the antenna delay, expected to be the same for all anchors.
| Physical | Raw range measurements | |||
| Anchor | Distance | Average | Std dev | Err |
| 0 | 2.80 | 2.46 | 0.025 | 0.34 |
| 1 | 2.87 | 2.58 | 0.006 | 0.30 |
| 2 | 2.69 | 2.30 | 0.002 | 0.40 |
| 3 | 2.77 | 2.55 | 0.017 | 0.22 |
| 4 | 2.27 | 1.97 | 0.041 | 0.29 |
| 5 | 2.20 | 1.90 | 0.008 | 0.30 |
