projects:bolt:index [2019-10-02 13:59] tobias |
projects:bolt:index [2019-10-08 14:17] tobias |
+ | The Crazyflie Bolt is currently part of our [[https:// | ||
====== Crazyflie Bolt ====== | ====== Crazyflie Bolt ====== | ||
- | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1 but in a slightly bit bigger package. | + | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1, but in a slightly bit bigger package. |
+ | ===== Board renderings ===== | ||
+ | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
- | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
Line 13: | Line 20: | ||
===== Features and differences from Crazyflie 2.1 ===== | ===== Features and differences from Crazyflie 2.1 ===== | ||
* Fully compatible with the CF2 firmware, expansion decks as well as radio. | * Fully compatible with the CF2 firmware, expansion decks as well as radio. | ||
- | * Connectors | + | * 4 x connectors |
* Power distributions built into controller board. (Max ~8A per motor controller) with XT30 connector. | * Power distributions built into controller board. (Max ~8A per motor controller) with XT30 connector. | ||
* Motor controllers can be switched off by the system (MOSFET) so the system can go into deep sleep and only consume around 50uA. | * Motor controllers can be switched off by the system (MOSFET) so the system can go into deep sleep and only consume around 50uA. | ||
Line 31: | Line 38: | ||
+ | ===== General setup ===== | ||
+ | <WRAP center round warning> | ||
+ | ====A bigger quadrotor is dangerous so make sure to be SAFE!==== | ||
+ | * To not exceed the 8A / ESC connector output the battery voltage, motor and propeller should be selected so this does not happen. The ESC can be rated higher as it does not noticeably effect current draw, only efficiency. | ||
+ | * Preferably select a frame so decks can be attached. It is hard to make e.g. the flow v2 deck and lighthouse deck work at the same time as the battery needs to be placed somewhere, which is normally in the center, above or below the Bolt control board. | ||
+ | * 4in1 ESCs can be convenient but for the Bolt it is often better to use 4 separate ESC mounted on the arms as this frees up space for decks. | ||
+ | * If higher then 8A is wanted only connect the signal wires from the ESC connectors to the ESC. Preferably still power the Bolt control board via the battery connector so the battery voltage can be monitored. | ||
+ | ===== Configuration ===== | ||
+ | The Crazyflie firmware will automatically detect that it is running on a Bolt and activate the right modules. However some of the configurations still has to be done during compile time and making them run time configurable is currently work in progress. | ||
+ | ===== Current firmware status notes (2019-10)===== | ||
+ | * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https:// | ||
+ | * External battery voltage/ | ||
+ | * The ESC PWM output is set by default to 400Hz. Use ESCs which can handle this or compile with [[https:// | ||
+ | * It is wise to do a range test before flying far away. | ||
+ | * **Be safe**, it is experimental software. Run all testing **without** props! |
