projects:bolt:index [2019-10-08 14:06] tobias |
projects:bolt:index [2019-12-09 15:17] tobias [Specification] |
Line 5: | Line 5: | ||
====== Crazyflie Bolt ====== | ====== Crazyflie Bolt ====== | ||
- | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1 but in a slightly bit bigger package. | + | The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1, but in a slightly bit bigger package. |
+ | ===== Board renderings ===== | ||
+ | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
- | The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames. | ||
- | Please see the shop product page for full specification | + | Please see the [[https:// |
===== Features and differences from Crazyflie 2.1 ===== | ===== Features and differences from Crazyflie 2.1 ===== | ||
Line 30: | Line 33: | ||
===== Power ===== | ===== Power ===== | ||
- | The Bolt contains a power distribution board (PDB) but it is a bit limiting. | + | The Bolt contains a power distribution board (PDB) but it is a bit limiting. |
===== Schematics ===== | ===== Schematics ===== |
