projects:crazyflie2:debugadapter:index [2014-12-19 16:18] macke created |
projects:crazyflie2:debugadapter:index [2016-05-07 19:01] arnaud [Connectors] |
+ | ====== Debug adapter ====== | ||
+ | The debug adapter enables users to easily connect JTAG/SWD debuggers to the Crazyflie 2.0 platform. For debugging the STM32F4 no soldering is required, but soldering is required for debugging the nRF51. | ||
+ | ====== Assembly ====== | ||
+ | The Debug adapter kit contains the following: | ||
+ | * The nRF debug connector for soldering to the Crazyflie 2.0 | ||
+ | * A nylon screw and nut for securely attaching the nRF51 debug connector | ||
+ | * The debug adapter for connecting the debugger | ||
+ | * A cable for connecting to the Crazyflie 2.0 | ||
+ | Below are two images showing how the nRF51 debug connector should be soldered to the Crazyflie 2.0. | ||
+ | ====== Connectors ====== | ||
+ | All the connectors are connected together, so any combination of debuggers will work. I.e using the STM32 Discovery board for debugging of the nRF51, or a ARM JTAG to Cortex M debug converter. | ||
+ | Here's a short explanation of the connectors: | ||
+ | * **Cortex M debug**: Pinout compatible with Cortex M debug for SWD/ | ||
+ | * **STM32 Discovery debug**: Pinout compatible with SWD/SWO of STM32 Discovery boards (so you can directly use these boards for debugging the Crazyflie) | ||
+ | * **ARM JTAG**: Pinout compatible with ARM JTAG 20 pin | ||
+ | * **Reset button**: Used to reset the target you are debugging | ||
+ | * **Reset selector** | ||
+ | * Reset btn to <-> SDWIO: For nRF51 debugging (reset done by holding SWD IO line low) | ||
+ | * Reset btn to <-> NRST: For STM32F debugging (reset done by holding NRST low) | ||
+ | * **Crazyflie 2.0 SWV**: Connect to Crazyflie 2.0 for nRF51 or STM32F4 debugging | ||
+ | * **nRF51 1:1**: 1:1 match with nRF51 debug pinout on the Crazyflie 2.0, pinout: | ||
+ | - SWIO | ||
+ | - GND | ||
+ | - VCC | ||
+ | - SWCLK |
