User Tools
Site Tools
projects:crazyflie2:debugadapter:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie2:debugadapter:index [2014-12-19 16:52]
macke
projects:crazyflie2:debugadapter:index [2021-06-24 16:25]
Line 1: Line 1:
 +</WRAP>
 +====== Debug adapter ======
 +The debug adapter enables users to easily connect JTAG/SWD debuggers to the Crazyflie 2.X platform. For debugging the STM32F4 no soldering is required, but soldering is required for debugging the nRF51.
 +====== Assembly ======
 +The Debug adapter kit contains the following:
 +  * The nRF debug connector for soldering to the Crazyflie 2.X
 +  * A nylon screw and nut for securely attaching the nRF51 debug connector
 +  * The debug adapter for connecting the debugger
 +  * A cable for connecting to the Crazyflie 2.X
 +Below are two images showing how the nRF51 debug connector should be soldered to the Crazyflie 2.X.
 +{{:projects:crazyflie2:debugadapter:debug_adapter_top.jpg?500|}}
 +{{:projects:crazyflie2:debugadapter:debug_adapter_bottom.jpg?500|}}
 +====== Connectors ======
 +{{:projects:crazyflie2:debugadapter:debug_adapter_parts.png?700|}}
 +All the connectors are connected together, so any combination of debuggers will work. I.e using the STM32 Discovery board for debugging of the nRF51, or a ARM JTAG to Cortex M debug converter.
 +Here's a short explanation of the connectors:
 +  * **Cortex M debug**: Pinout compatible with Cortex M debug for SWD/SWO/JTAG
 +  * **STM32 Discovery debug**: Pinout compatible with SWD/SWO of STM32 Discovery boards (so you can directly use these boards for debugging the Crazyflie)
 +  * **ARM JTAG**: Pinout compatible with ARM JTAG 20 pin
 +  * **Reset button**: Used to reset the target you are debugging
 +  * **Reset selector**
 +    * Reset btn to <-> SDWIO: For nRF51 debugging (reset done by holding SWD IO line low)
 +    * Reset btn to <-> NRST: For STM32F debugging (reset done by holding NRST low)
 +  * **Crazyflie 2.0 SWV**: Connect to Crazyflie 2.X for nRF51 or STM32F4 debugging
 +  * **nRF51 1:1**: 1:1 match with nRF51 debug pinout on the Crazyflie 2.X, pinout:
 +    - SWIO
 +    - GND
 +    - VCC
 +    - SWCLK
 +====== Debug instructions ======
 +For some basic debug instructions using the VM go [[projects:virtualmachine:jtag_debug|here]]
projects/crazyflie2/debugadapter/index.txt · Last modified: 2021-06-24 16:25 by kimberly
