projects:crazyflie2:expansionboards:bigquad [2018-11-06 10:11] tobias |
projects:crazyflie2:expansionboards:bigquad [2021-06-24 16:09] (current) kimberly |
| <WRAP center round info> | <WRAP center round info> | ||
| The BigQuad deck is currently part of our [[https:// | The BigQuad deck is currently part of our [[https:// | ||
| Line 55: | Line 59: | ||
| BigQuad expansion deck {{: | BigQuad expansion deck {{: | ||
| - | ===== Compatibility with Loco deck and Flow (v2) deck ===== | + | ===== Compatibility with Loco deck, microSD |
| + | The Loco deck, microSD and Flow (v2) deck all uses the SPI bus. As the BigQuad deck uses the deck SPI buss pins for possible voltage and current measurement, | ||
| + | - By removing capacitor C1 on the BigQuad deck. See image on the right. | ||
| + | - Not having BQ_DECK_ENABLE_PM defined. | ||
| + | - Disabling the extRx functionality by commenting out [[https:// | ||
| + | Capacitor C1 is used to filter the current measurement and removing this has the effect that it will not be filtered any more. Still possible to use it if a deck using the SPI is not wanted any more. | ||
| + | To make it work with the Flow (v2) deck more changes/ | ||
| + | - The Flow HW ChipSelect (IO3) interfere with BigQuad PWM and needs to be moved. Cut trace and solder patch on Flow deck from IO3 to IO1. | ||
| + | - Change the CS pin in [[https:// | ||
| + | Next problem is how to mount the deck in a nice way on the quad, we leave that up to you. | ||
| ====== Setting up ====== | ====== Setting up ====== | ||
| <WRAP center round warning> | <WRAP center round warning> | ||
| Line 62: | Line 78: | ||
| Currently there is only a basic setup but as the development advances so will the documentation. | Currently there is only a basic setup but as the development advances so will the documentation. | ||
| - | Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. | + | Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. **Note** that the 5V is needed for the motor signals and is not optional. |
| ===== Basic connection diagram ===== | ===== Basic connection diagram ===== | ||
| Line 91: | Line 107: | ||
| Clean and build the firmware and flash it using you preferred method. | Clean and build the firmware and flash it using you preferred method. | ||
| Now when the Crazyflie 2.0 is started and it is connected to the BigQuad deck it will start outputting PWM signals to the ESC connectors. The motors [[https:// | Now when the Crazyflie 2.0 is started and it is connected to the BigQuad deck it will start outputting PWM signals to the ESC connectors. The motors [[https:// | ||
| - | ===== Current firmware status notes (2016-03)===== | + | ===== Current firmware status notes (2019-10)===== |
| * CPPM input is working but calibration and dynamic channel setup is not implemented yet. Doing the first tests with cfclient and gamepad is wise but might not be as reliable as a RC transmitter and receiver, yet. | * CPPM input is working but calibration and dynamic channel setup is not implemented yet. Doing the first tests with cfclient and gamepad is wise but might not be as reliable as a RC transmitter and receiver, yet. | ||
| * When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not. | * When the BQ-Deck is detected it will automatically switch to brushless motor drivers. It will be noted in the cfclient console if it is detected or not. | ||
| * 1mbit or 2mbit datarate seem to be more stable when communicating with the BigQuad deck attached. It is wise to do a range test before flying far away. | * 1mbit or 2mbit datarate seem to be more stable when communicating with the BigQuad deck attached. It is wise to do a range test before flying far away. | ||
| - | * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https:// | + | * Different PID tuning parameters might be needed for it to fly well. Currently this has to be [[https:// |
| * External battery voltage/ | * External battery voltage/ | ||
| - | * The PWM output is set to 400Hz. Use ESCs which can handle this or compile with [[https:// | + | * The PWM output is set to 400Hz. Use ESCs which can handle this or compile with [[https:// |
| * **Be safe**, it is experimental software. Run all testing **without** props! | * **Be safe**, it is experimental software. Run all testing **without** props! | ||
| ====== Reference setup ====== | ====== Reference setup ====== | ||
