projects:crazyflie2:expansionboards:breakout [2016-02-04 16:17] kristoffer |
projects:crazyflie2:expansionboards:breakout [2021-06-24 16:13] (current) kimberly |
| - | ====== Breackout expansion deck ====== | + | <WRAP center round important 60%> |
| + | [[https:// | ||
| - | The breakout expansion | + | ====== Breakout |
| - | The deck is shipped without 100mil connector. To be used on a breadboard 100mil 10 pin male should be soldered. | + | The breakout deck is designed to be soldered to 100mil breadboard or prototyping board. The aim is to ease prototyping by connecting breadboard circuits to Crazyflie 2.0. It can also be used to make a bigger system using Crazyflie 2.0 as a component. The breakout board is also very useful to measure signals, for example by sticking oscilloscope probes in the 100mil connector holes. |
| + | The deck is shipped without | ||
| The 100mil connector is cabled directly to the expansion port connectors. | The 100mil connector is cabled directly to the expansion port connectors. | ||
