projects:crazyflie2:expansionboards:breakout [2014-09-24 14:22] arnaud |
projects:crazyflie2:expansionboards:breakout [2015-07-15 16:31] 127.0.0.1 external edit |
Line 8: | Line 8: | ||
+ | * Makes all 20 pins in the Crazyflie 2.0 expansion port available | ||
+ | * 2.54mm header that fits a breadboard (not included) | ||
+ | * Screenprint showing all signal names | ||
+ | * Footprint for optional 1-wire memory (not mounted) | ||
+ | * Mechanical specification: | ||
+ | * Weight: 1.5 g | ||
+ | * Size (WxHxD): 27x28x4mm | ||
