projects:crazyflie2:expansionboards:breakout [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie2:expansionboards:breakout [2016-02-04 16:17] kristoffer |
- | ====== Breackout expansion | + | ====== Breackout expansion |
- | The breakout expansion | + | The breakout expansion |
- | The board is shipped without 100mil connector. To be used on a breadboard 100mil 10 pin male should be soldered. | + | The deck is shipped without 100mil connector. To be used on a breadboard 100mil 10 pin male should be soldered. |
The 100mil connector is cabled directly to the expansion port connectors. | The 100mil connector is cabled directly to the expansion port connectors. |
