projects:crazyflie2:expansionboards:buzzer [2016-02-04 16:13] kristoffer created |
projects:crazyflie2:expansionboards:buzzer [2016-03-27 03:17] fred [Changing the sounds] |
====== Buzzer expansion deck ====== | ====== Buzzer expansion deck ====== | ||
- | The buzzer deck contains a low profile piezo buzzer and have a 1-wire memory which enables the Crazyflie to automatically detect the deck. | + | The buzzer deck contains a low profile piezo buzzer and has a 1-wire memory which enables the Crazyflie to automatically detect the deck. |
The deck is designed to be installed either on the top or the bottom of the Crazyflie. | The deck is designed to be installed either on the top or the bottom of the Crazyflie. | ||
Line 10: | Line 10: | ||
* Based on the CMT-1203-SMT | * Based on the CMT-1203-SMT | ||
* 1-wire memory for automatic expansion board detection | * 1-wire memory for automatic expansion board detection | ||
- | * Designed for mounting over or under the Crazyflie | + | * Designed for mounting over or under the Crazyflie |
* Mechanical specification: | * Mechanical specification: | ||
* Weight: 1.8g | * Weight: 1.8g | ||
Line 19: | Line 19: | ||
Buzzer expansion deck {{: | Buzzer expansion deck {{: | ||
+ | ===== Changing the sounds ===== | ||
+ | Changing the sounds requires modifications to the firmware. The code for the sounds is located in [[https:// | ||
+ | A sequences is defined in the .notes member of the Melody struct. The notes are defined as tuples of a note (pitch) and duration. A sequence must be ended with the end marker. | ||
+ | The effects are defined in the effects array. Each entry takes a function to call and related parameters. | ||
+ | To add a new melody, use the melodyplayer function for the .call member and assign your Melody struct to the .melody member. | ||
+ | ===== Parameters ===== | ||
+ | ^Name^Type^Access^Value (default)^Description^ | ||
+ | |sound.effect|uint8_t|RW|0|Sound effect (0=off, [...], 10=Star Wars Imperial March, [...])| | ||
+ | |sound.freq|uint16_t|RW|4000| | | ||
+ | |sound.neffect|uint32_t|RO|13|Number of available sound effects| | ||
+ | |sound.ratio|uint8_t|RW|0| | |
