projects:crazyflie2:expansionboards:index [2017-03-01 11:05] tobias [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2018-12-18 11:34] tobias old revision restored (2018-06-21 10:07) |
Line 8: | Line 8: | ||
+ | * [[projects: | ||
Line 35: | Line 36: | ||
Line 50: | Line 58: | ||
Line 65: | Line 80: | ||
| bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | | bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | ||
| bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
- | | bcZRange | + | | bcZRanger |
+ | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
+ | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | |
