projects:crazyflie2:expansionboards:index [2017-03-01 11:05] tobias [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2017-10-05 14:56] arnaud [Deck info] |
Line 8: | Line 8: | ||
+ | * [[projects: | ||
Line 50: | Line 51: | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. Assignments in parenthesis are connected via solder bridges or 0 Ohm resistors. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. Assignments in parenthesis are connected via solder bridges or 0 Ohm resistors. | ||
Line 66: | Line 68: | ||
| bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
| bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
+ | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
