projects:crazyflie2:expansionboards:index [2017-03-14 13:22] tobias [Expansion decks] |
projects:crazyflie2:expansionboards:index [2018-10-30 13:37] kristoffer |
Line 8: | Line 8: | ||
+ | [[projects: | ||
Line 36: | Line 37: | ||
Line 51: | Line 59: | ||
Line 67: | Line 82: | ||
| bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | | bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
| bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
+ | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
