projects:crazyflie2:expansionboards:index [2017-06-28 14:14] macke [Deck info] |
projects:crazyflie2:expansionboards:index [2018-03-27 10:43] macke [Deck info] |
Line 51: | Line 51: | ||
Line 69: | Line 73: | ||
| bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
| bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
