projects:crazyflie2:expansionboards:index [2017-06-28 14:14] macke [Deck info] |
projects:crazyflie2:expansionboards:index [2019-02-14 14:14] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 10: | Line 11: | ||
+ | [[projects: | ||
Line 36: | Line 40: | ||
Line 51: | Line 62: | ||
- | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | + | ^ bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | |
- | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | + | ^ bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes: | ||
