projects:crazyflie2:expansionboards:index [2017-10-05 13:41] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2018-05-08 13:10] tobias [Deck info] |
Line 51: | Line 51: | ||
- | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | N/A | Above | N/A | N/A | | + | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | |
Line 69: | Line 75: | ||
| bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | ||
| bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
