projects:crazyflie2:expansionboards:index [2017-10-05 13:41] arnaud [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2017-10-05 14:56] arnaud [Deck info] |
Line 51: | Line 51: | ||
- | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | N/A | Above | N/A | N/A | | + | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA |
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. Assignments in parenthesis are connected via solder bridges or 0 Ohm resistors. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. Assignments in parenthesis are connected via solder bridges or 0 Ohm resistors. |
