projects:crazyflie2:expansionboards:index [2017-10-05 14:53] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2018-12-18 11:34] tobias old revision restored (2018-06-21 10:07) |
Line 36: | Line 36: | ||
Line 51: | Line 58: | ||
| 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | ||
Line 70: | Line 83: | ||
| bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
| bcOA | | | X | X | | | | | | | | | | | | VCC | | | bcOA | | | X | X | | | | | | | | | | | | VCC | | ||
