projects:crazyflie2:expansionboards:index [2017-10-05 14:53] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2019-02-14 13:47] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 10: | Line 11: | ||
+ | [[projects: | ||
Line 36: | Line 40: | ||
Line 51: | Line 62: | ||
| 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | ||
- | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | + | ^ bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | |
- | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | + | ^ bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | |
- | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
+ | ^ bcLedRing | ||
+ | ^ bcQi | yes | yes | | ||
+ | ^ bcGPS | yes | ||
+ | ^ bcUSD | yes | *1 | | ||
+ | ^ bcDWM | yes | ||
+ | ^ bcBigQuad | ||
+ | ^ bcBuzzer | ||
+ | ^ bcZRanger | ||
+ | ^ bcFlow | ||
+ | ^ bcOA | yes | yes | | ||
+ | ^ bcMultiranger | yes | yes | | ||
+ | ^ bcMocap | ||
+ | ^ bcLighthouse4 | yes | *2 | | ||
+ | | ^ bcLedRing ^ bcQi ^ bcGPS ^ bcUSD ^ bcDWM ^ bcBigQuad ^ bcBuzzer ^ bcESP ^ bcZRanger ^ bcFlow ^ bcOA ^ bcMultiranger ^ bcMocap ^ bcLighthouse4 ^ | ||
+ | ^ bcQi | | ||
+ | ^ bcGPS | yes | yes | | yes | ||
+ | ^ bcUSD | yes | yes | yes | ||
+ | ^ bcDWM | yes | yes | | *1 | | yes | yes | yes | yes | yes | yes | yes | yes | *2 | | ||
+ | ^ bcBuzzer | ||
+ | ^ bcESP | yes | yes | yes | yes | yes | ||
+ | ^ bcFlow | ||
+ | ^ bcOA | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | | yes | yes | yes | | ||
+ | ^ bcMultiranger | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | yes | | yes | yes | | ||
+ | ^ bcMocap | ||
+ | ^ bcLighthouse4 | yes | yes | | yes | *2 | *2 | yes | yes | yes | yes | yes | yes | yes | ||
+ | **Notes:** | ||
