projects:crazyflie2:expansionboards:index [2017-10-05 14:56] arnaud [Deck info] |
projects:crazyflie2:expansionboards:index [2018-10-30 13:37] kristoffer |
Line 10: | Line 10: | ||
- | * [[projects: | + | |
+ | [[projects: | ||
Line 36: | Line 37: | ||
Line 54: | Line 62: | ||
| 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | ||
Line 70: | Line 84: | ||
| bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
| bcOA | | | X | X | | | | | | | | | | | | VCC | | | bcOA | | | X | X | | | | | | | | | | | | VCC | | ||
