projects:crazyflie2:expansionboards:index [2017-05-23 09:34] jan [Expansion decks] |
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] kimberly |
Line 4: | Line 9: | ||
+ | * [[projects: | ||
Line 9: | Line 15: | ||
- | * [[projects: | ||
+ | [[projects: | ||
Line 36: | Line 46: | ||
Line 51: | Line 68: | ||
- | | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | TBD | TBD | | + | | 0xBC | 0x0A | bcFlow | Flow | 1.6g | ~40mA | Below | [[projects: |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Flow, Flow V2 | ||
+ | **Notes: | ||
