projects:crazyflie2:expansionboards:index [2017-06-28 14:14] macke [Deck info] |
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] kimberly |
Line 4: | Line 9: | ||
+ | * [[projects: | ||
Line 10: | Line 16: | ||
+ | [[projects: | ||
Line 36: | Line 46: | ||
Line 51: | Line 68: | ||
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Flow, Flow V2 | ||
+ | **Notes: | ||
