projects:crazyflie2:expansionboards:index [2018-03-27 10:46] macke [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2018-10-30 13:37] kristoffer |
Line 10: | Line 10: | ||
- | * [[projects: | + | |
+ | [[projects: | ||
Line 36: | Line 37: | ||
Line 56: | Line 64: | ||
| 0xBC | 0x0C | bcMultiranger | Multi-ranger | N/A | ~90mA (depending on mode) | Above | N/A | N/A | | | 0xBC | 0x0C | bcMultiranger | Multi-ranger | N/A | ~90mA (depending on mode) | Above | N/A | N/A | | ||
| 0xBC | 0x0D | bcMocap | Mocap marker deck | N/A | 0mA | Above | N/A | N/A | | | 0xBC | 0x0D | bcMocap | Mocap marker deck | N/A | 0mA | Above | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. |
