projects:crazyflie2:expansionboards:index [2018-06-21 10:07] tobias [Expansion port pinout] |
projects:crazyflie2:expansionboards:index [2019-02-14 14:14] kristoffer |
Line 4: | Line 4: | ||
+ | * [[projects: | ||
Line 10: | Line 11: | ||
+ | [[projects: | ||
Line 65: | Line 69: | ||
| 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | | 0xBC | 0x0E | bcZRanger2 | Z-Ranger v2 | 1.3g | ~15mA | Below | N/A | N/A | | ||
| 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | | 0xBC | 0x0F | bcFlow2 | Flow v2 | 1.6g | ~40mA | Below | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | ||
Line 72: | Line 78: | ||
- | | bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | + | ^ bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | |
- | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | + | ^ bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | |
- | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
- | | bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | + | ^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | |
- | | bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | | + | ^ bcMocap | | | | | | //(X)// | //(X)// | | | | | | | | | N/A | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | yes | yes | | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Z-Ranger | ||
+ | ^ Flow | | | *1 | yes | ||
+ | **Notes:** | ||
