projects:crazyflie2:expansionboards:ledring [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyflie2:expansionboards:ledring [2016-03-27 01:45] fred |
- | ====== LED Ring expansion | + | ====== LED Ring expansion |
- | The LED ring expansion | + | The LED ring expansion |
- | The board is designed to be installed as the last board on the bottom of the Crazyflie 2.0. It does not have pass-through holes for the expansion port connector. | + | The deck is designed to be installed as the last deck on the bottom of the Crazyflie 2.0. It does not have pass-through holes for the expansion port connector. |
Line 11: | Line 11: | ||
* DC-DC step-up/ | * DC-DC step-up/ | ||
- | * 12 independantly | + | * 12 independently |
* 2 strong white LEDs facing forward | * 2 strong white LEDs facing forward | ||
- | * 1-wire memory for automatic expansion | + | * 1-wire memory for automatic expansion |
* Designed for mounting under the Crazyflie facing downwards | * Designed for mounting under the Crazyflie facing downwards | ||
* Mechanical specification: | * Mechanical specification: | ||
Line 21: | Line 21: | ||
===== Schematic ===== | ===== Schematic ===== | ||
- | Led ring expansion | + | Led ring expansion |
