projects:crazyflie2:expansionboards:ledring [2016-02-04 16:14] kristoffer |
projects:crazyflie2:expansionboards:ledring [2019-07-02 16:12] victor |
Line 11: | Line 11: | ||
* DC-DC step-up/ | * DC-DC step-up/ | ||
- | * 12 independantly | + | * 12 independently |
* 2 strong white LEDs facing forward | * 2 strong white LEDs facing forward | ||
* 1-wire memory for automatic expansion deck detection | * 1-wire memory for automatic expansion deck detection | ||
Line 23: | Line 23: | ||
Led ring expansion deck {{: | Led ring expansion deck {{: | ||
+ | ===== Parameters ===== | ||
+ | ^Name^Type^Access^Value (default)^Description^ | ||
+ | |ring.effect|uint8_t|RW|6|Ring effect (0=off, 1=White spinner, 2=Color spinner, 3=Tilt effect, 4=Brightness effect, 5=Color spinner2, 6=Double spinner, 7=Solid color effect, 8=Factory test, 9=Battery status, 10=Boat lights, 11=Alert, 12=Gravity, 13=N/A)| | ||
+ | |ring.emptyCharge|float|RW|3.099..| | | ||
+ | |ring.fullCharge|float|RW|4.199..| | | ||
+ | |ring.glowstep|float|RW|0.050..| | | ||
+ | |ring.headlightEnable|uint8_t|RW|0|Headlight LEDs (0=off, 1=on)| | ||
+ | |ring.neffect|uint32_t|RO|13|Number of available ring effects| | ||
+ | |ring.solidBlue|uint8_t|RW|20| | | ||
+ | |ring.solidGreen|uint8_t|RW|20| | | ||
+ | |ring.solidRed|uint8_t|RW|20| | | ||
+ | ====== Getting started with the LED Ring expansion deck ====== | ||
+ | To get started with the LED Ring expansion deck you can either control the LEDs using the client, or by code. | ||
+ | ==== Using the Client ==== | ||
+ | Start the cfclient | ||
+ | Connect to your Crazyflie and make sure your //LED// tab is visible. | ||
+ | If not, go to View -> Tabs -> LED tab | ||
+ | Now you can address each LED individually and set its RGB color. | ||
+ | ==== Using code ==== | ||
+ | You can easily control the LEDs by using the [[https:// | ||
+ | There' | ||
+ | * basicLedparamSync.py | ||
+ | * basicLedmemSync.py | ||
+ | You can then modify the scripts to your needs by adjusting the color effects, fade effects, RBG values, timings and much more. There' |
