projects:crazyflie2:expansionboards:ledring [2014-09-24 15:06] arnaud created |
projects:crazyflie2:expansionboards:ledring [2021-06-24 16:09] (current) kimberly |
| - | ====== LED Ring expansion board ====== | + | <WRAP center round important 60%> |
| - | The LED ring expansion | + | ====== |
| - | The board is designed to be installed as the last board on the bottom of the Crazyflie 2.0. It does not have pass-throw holes for the expansion port connector. | + | The LED ring expansion deck contains two powerful front-facing white LEDs and 12 bottom-facing RGB individually addressable LEDs (it uses the same LEDs as used in the NeoPixel products by Adafruit). |
| + | The deck is designed to be installed as the last deck on the bottom of the Crazyflie 2.0. It does not have pass-through | ||
| + | The RGB LEDs are connected in in series and can be addressed individually. When a new color is sent to U1, the U1 color is sent to U2, the U2 to U3 and so on. So sending 12 colors to U1 will update the full ring. Drivers for the ring exist in the Crazyflie 2.0 firmware. | ||
| + | ===== Specification ===== | ||
| + | * DC-DC step-up/ | ||
| + | * 12 independently addressable RGB LED modules facing downwards ([[http:// | ||
| + | * 2 strong white LEDs facing forward | ||
| + | * 1-wire memory for automatic expansion deck detection | ||
| + | * Designed for mounting under the Crazyflie facing downwards | ||
| + | * Mechanical specification: | ||
| + | * Weight: 3.3g | ||
| + | * Size (WxHxD): 33x33x5.5mm | ||
| + | ===== Schematic ===== | ||
| + | Led ring expansion deck {{: | ||
| + | ===== Parameters ===== | ||
| + | ^Name^Type^Access^Value (default)^Description^ | ||
| + | |ring.effect|uint8_t|RW|6|Ring effect (0=off, 1=White spinner, 2=Color spinner, 3=Tilt effect, 4=Brightness effect, 5=Color spinner2, 6=Double spinner, 7=Solid color effect, 8=Factory test, 9=Battery status, 10=Boat lights, 11=Alert, 12=Gravity, 13=N/A)| | ||
| + | |ring.emptyCharge|float|RW|3.099..| | | ||
| + | |ring.fullCharge|float|RW|4.199..| | | ||
| + | |ring.glowstep|float|RW|0.050..| | | ||
| + | |ring.headlightEnable|uint8_t|RW|0|Headlight LEDs (0=off, 1=on)| | ||
| + | |ring.neffect|uint32_t|RO|13|Number of available ring effects| | ||
| + | |ring.solidBlue|uint8_t|RW|20| | | ||
| + | |ring.solidGreen|uint8_t|RW|20| | | ||
| + | |ring.solidRed|uint8_t|RW|20| | | ||
| + | ====== Getting started with the LED Ring expansion deck ====== | ||
| + | To get started with the LED Ring expansion deck you can either control the LEDs using the client, or by code. | ||
| + | ==== Using the Client ==== | ||
| + | Start the cfclient | ||
| + | Connect to your Crazyflie and make sure your //LED// tab is visible. | ||
| + | If not, go to View -> Tabs -> LED tab | ||
| + | Now you can address each LED individually and set its RGB color. | ||
| + | ==== Using code ==== | ||
| + | You can easily control the LEDs by using the [[https:// | ||
| + | There' | ||
| + | * basicLedparamSync.py | ||
| + | * basicLedmemSync.py | ||
| + | You can then modify the scripts to your needs by adjusting the color effects, fade effects, RBG values, timings and much more. There' | ||
