projects:crazyflie2:expansionboards:ledring [2016-03-27 01:45] fred |
projects:crazyflie2:expansionboards:ledring [2021-06-24 16:09] (current) kimberly |
| ====== LED Ring expansion deck ====== | ====== LED Ring expansion deck ====== | ||
| Line 23: | Line 27: | ||
| Led ring expansion deck {{: | Led ring expansion deck {{: | ||
| + | ===== Parameters ===== | ||
| + | ^Name^Type^Access^Value (default)^Description^ | ||
| + | |ring.effect|uint8_t|RW|6|Ring effect (0=off, 1=White spinner, 2=Color spinner, 3=Tilt effect, 4=Brightness effect, 5=Color spinner2, 6=Double spinner, 7=Solid color effect, 8=Factory test, 9=Battery status, 10=Boat lights, 11=Alert, 12=Gravity, 13=N/A)| | ||
| + | |ring.emptyCharge|float|RW|3.099..| | | ||
| + | |ring.fullCharge|float|RW|4.199..| | | ||
| + | |ring.glowstep|float|RW|0.050..| | | ||
| + | |ring.headlightEnable|uint8_t|RW|0|Headlight LEDs (0=off, 1=on)| | ||
| + | |ring.neffect|uint32_t|RO|13|Number of available ring effects| | ||
| + | |ring.solidBlue|uint8_t|RW|20| | | ||
| + | |ring.solidGreen|uint8_t|RW|20| | | ||
| + | |ring.solidRed|uint8_t|RW|20| | | ||
| + | ====== Getting started with the LED Ring expansion deck ====== | ||
| + | To get started with the LED Ring expansion deck you can either control the LEDs using the client, or by code. | ||
| + | ==== Using the Client ==== | ||
| + | Start the cfclient | ||
| + | Connect to your Crazyflie and make sure your //LED// tab is visible. | ||
| + | If not, go to View -> Tabs -> LED tab | ||
| + | Now you can address each LED individually and set its RGB color. | ||
| + | ==== Using code ==== | ||
| + | You can easily control the LEDs by using the [[https:// | ||
| + | There' | ||
| + | * basicLedparamSync.py | ||
| + | * basicLedmemSync.py | ||
| + | You can then modify the scripts to your needs by adjusting the color effects, fade effects, RBG values, timings and much more. There' | ||
