projects:crazyflie2:expansionboards:mocapmarker [2019-04-01 12:57] tobias |
projects:crazyflie2:expansionboards:mocapmarker [2021-06-24 16:14] kimberly |
====== MoCap marker deck ====== | ====== MoCap marker deck ====== | ||
- | Deck that supports | + | The Mocap marker deck eases the mounting |
+ | There are also two footprints where push buttons that can be fitted. This can come in handy if an action-trigger is wanted. The top one is connected to IO_3 and the bottom one to IO_2. They will ground when pushed so the GPIO should enable the pull-up. | ||
Line 8: | Line 14: | ||
===== Schematic ===== | ===== Schematic ===== | ||
- | Motion capture | + | MoCap marker deck RevD {{ : |
