User Tools
Site Tools
projects:crazyflie2:expansionboards:multiranger
Differences
Link to this comparison view
projects:crazyflie2:expansionboards:multiranger [2018-10-23 12:56]
projects:crazyflie2:expansionboards:multiranger [2021-06-24 16:14] (current)
Line 1: Line 1:
 +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/]] and go to the menu 'products'.
 +</WRAP>
 ====== Multi-ranger deck ====== ====== Multi-ranger deck ======
 The multi-ranger deck gives Crazyflie 2.0 the ability to sense the distance to objects around it with mm precision, up to 4 meters away. It contains 5 VL53L1X ranging sensors facing the front, left, back, right and up. When used together with the Flow deck the Crazyflie 2.0 can autonomously move around and avoid obstacles. The multi-ranger deck gives Crazyflie 2.0 the ability to sense the distance to objects around it with mm precision, up to 4 meters away. It contains 5 VL53L1X ranging sensors facing the front, left, back, right and up. When used together with the Flow deck the Crazyflie 2.0 can autonomously move around and avoid obstacles.
projects/crazyflie2/expansionboards/multiranger.txt · Last modified: 2021-06-24 16:14 by kimberly
