projects:crazyflie2:expansionboards:template [2014-10-20 21:58] macke |
projects:crazyflie2:expansionboards:template [2021-06-10 14:28] (current) kimberly |
| - | ====== Crazyflie 2.0 expansion board template ====== | + | <WRAP center round important 60%> |
| - | Users that want to design their own expansion boards for the Crazyflie 2.0 can use the expansion board template to get started. It contains the initial schematic with the expansion connector, the component mapping and the layout including the connector. In order for users to easier be able to see how their expansion board will fit we have added the Crazyflie 2.0 outline as well as some key components. The added drawings are on the Eco1.User layer. | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// |
| + | [[https:// | ||
| + | ====== Crazyflie 2.0 deck template ====== | ||
| + | Users that want to design their own decks (expansion boards) for the Crazyflie 2.0 can use the deck template to get started. It contains the initial schematic with the expansion connector, the component mapping and the layout including the connector. In order for users to easier be able to see how their expansion board will fit we have added the Crazyflie 2.0 outline as well as some key components. The added drawings are on the Eco1.User layer. | ||
| + | The [[https:// | ||
| The project is made using KiCad and is licensed under CC-BY 4.0. | The project is made using KiCad and is licensed under CC-BY 4.0. | ||
